How to Manually Translate Guides
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
All Time:
130
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to create a guide translation manually when the language version doesn't exist yet. If a clearly labelled automated translation is already live, open that version and edit it to proofread the existing text instead.
Read the iFixit Translator Guidelines before you begin. Check warnings, actions, omitted text, numbers, measurements, directions, tool and part names, and links against the source.
If the source guide itself is incorrect, improve the source first, then translate the correction. This makes the improvement available to every language.
Your corrections are preserved while the corresponding source content remains unchanged. If the source is updated, the existing translation—including community improvements—is used as context for the new version, but affected passages may need to change too.
Thank you for helping make repair information available around the world!
    1. How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 1 of 3 How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 2 of 3 How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 3 of 3
      • The Help Translate button in the footer will lead you to an overview of the most popular guides not available in your language. But you're also welcome to start translating any guide you fall in love with!
      • On Translate Missing, choose a guide to translate. The page automatically shows content missing from the language you’re currently browsing in.
      • To translate into a different language, use the language dropdown on the Translate Missing page. If you choose a wiki, follow How to Manually Translate Wikis.
    2. How to Manually Translate Guides: step 2, image 1 of 1
      • After you select a guide, the translation interface opens automatically. The source language appears on the left, and the target-language fields appear on the right.
      • Enter the translation, then select Save.
    3. How to Manually Translate Guides, Translating eventual prereqs: step 3, image 1 of 1
      • Check whether the guide uses prerequisite guides that also need translation.
      • The translation status of each prerequisite appears below the guide title and introduction.
      • Translate incomplete prerequisite guides first. This helps readers and gives you context for the main guide.
      • Learn more in Prerequisite Guides.
    4. How to Manually Translate Guides, Translating Guide Steps: step 4, image 1 of 1
      • Select Steps next to Guide on the translation page.
      • Select a step to translate.
      • You can translate the steps in any order.
      • If the source guide is incorrect, improve the guide in its original language, then translate the improvement. Otherwise, the translation will become outdated when the source is corrected.
    5. How to Manually Translate Guides: step 5, image 1 of 1
      • The instructions field may be prefilled with source-language text. Replace all source text with your translation before selecting Save step.
      • You may use a translation tool such as DeepL for a first draft, but review and revise the result before saving.
      • If the translation exceeds the 350-character limit for a bullet, shorten it or split it into two bullets.
    6. How to Manually Translate Guides: step 6, image 1 of 2 How to Manually Translate Guides: step 6, image 2 of 2
      • You don't need to translate the entire guide at once.
      • Your translations are saved and can be completed later.
      • To check your progress or continue later, select Translate on the guide page.
      • The translation dashboard shows the status of each language and guide section.
    7. How to Manually Translate Guides, Review!: step 7, image 1 of 1
      • After translating every step, select View and read the guide in the target language.
      • Compare the translation with the source. Check warnings, actions, omitted text, numbers, measurements, directions, tool and part names, and links.
      • If the translation needs more work, return to the translation screen or edit an individual step.
      • Edits from contributors below the patrol threshold are saved as unverified revisions. Until someone reviews them in Patrol, readers can switch between the latest verified snapshot and the newer unverified version, which displays a warning banner. Learn more about Content Patrol.
Finish Line
iRobot
60 Guides authored
0 Guide Comments
