How to Manually Translate Guides
  1. How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 1 of 3 How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 2 of 3 How to Manually Translate Guides, How to Manually Translate Guides: step 1, image 3 of 3
    • The Help Translate button in the footer will lead you to an overview of the most popular guides not available in your language. But you're also welcome to start translating any guide you fall in love with!
    • Open the guide you would like to translate.
    • Expand the Language Menu from the site header and select the language you want to manually translate to.
  2. How to Manually Translate Guides: step 2, image 1 of 2 How to Manually Translate Guides: step 2, image 2 of 2
    • Click Translate in the subheader.
    • Seen here in Spanish, Traducir.
    • If you see a banner appear on the guide that says “This version may contain incorrect edits. Switch to the latest verified snapshot”, check back in a few days before starting your edit. That banner means someone else has suggested an edit, potentially a translation. They might accidentally overwrite your edits, or you might overwrite theirs!
  3. How to Manually Translate Guides, Translating eventual prereqs: step 3, image 1 of 1
    • Check whether the guide is using prerequisite guides that might need translation as well.
    • If the guide you’re translating has any prerequisites, they will automatically be displayed on top, together with their translation status.
    • In cases of incomplete translation of prerequisite guides, we strongly recommend translating those first, it helps users and gives you better context.
    • You can find more informations about prerequisite guides here.
  4. How to Manually Translate Guides: step 4, image 1 of 1
    • The page will refresh and display the Translation Page.
    • The translation will start with the introduction.
    • The left side of the page displays the guide's current language.
    • The right side of the page displays the language to which the guide will be translated.
    • If you exit out of the Translation Page, you will need to repeat Steps 1 and 2 to resume translating the guide.
  5. How to Manually Translate Guides: step 5, image 1 of 1
    • To start translating, enter the translation of each section into the text boxes on the right side of the page.
    • Those sections not yet translated will have the marker on the left of the text box that is a half filled red circle.
    • While translating a section, the marker on the left of the text box changes to an orange marker.
    • When the translation for a section is complete, the marker on the left of the text box changes to a green marker with a check.
  6. How to Manually Translate Guides, Translating the different introduction fields: step 6, image 1 of 1
    • Using the copy arrow can be specifically helpful in case of a long device name and model number which do not require a change in the target language.
    • Please check whether your translated Title includes the device’s name, component, and the guide type such as “replacement” or “repair”. The title should clearly convey what the guide will show and you’re welcome to step away from literal translation towards more clarity in the target language if needed.
    • The Search Summary should briefly explain what the guide will demonstrate.
    • The Introduction field should explain everything your reader should know before attempting the repair.
    • By default, each guide ends with a default Conclusion: “To reassemble your device, follow these instructions in reverse order”. You can always borrow this translated text from other guides in your target language—you don’t have to re-invent the wheel each time, and it helps with consistency.
    • When finished translating the introduction, click on the Save Changes button.
    • Review the Parts of a Guide Page to better understand the various elements that make up a guide.
  7. How to Manually Translate Guides, Translating Guide Steps: step 7, image 1 of 1
    • Click on a step to translate it.
    • The steps are listed below the Introduction edits on the Translation Page.
    • Steps do not need to be translated in order.
    • If you find that you know more about what you’re translating and you’d like to improve the guide, please improve the guide in its original language and then translate the improvement. Otherwise your translation will be flagged outdated once errors are corrected in the source language.
  8. How to Manually Translate Guides: step 8, image 1 of 2 How to Manually Translate Guides: step 8, image 2 of 2
    • Click Insert Translation Here to open the text box.
    • Here in Spanish, Insertar traduccion aqui.
    • Don’t forget to also add a translation for the step title if there is one.
  9. How to Manually Translate Guides: step 9, image 1 of 1
    • Enter the translation of the corresponding bullet into the text box.
    • When you're done, click Save.
    • Here in Spanish, Guardar.
    • After you save the changes, click the Back to Guide button to return to the Translation Page.
    • Here in Spanish, Volver a la Guia.
    • Repeat the process for each step in the guide.
    • Alternatively, navigate with the buttons Previous step and Next step.
    • Here in Spanish, Paso anterior and Siguiente paso.
  10. How to Manually Translate Guides: step 10, image 1 of 2 How to Manually Translate Guides: step 10, image 2 of 2
    • The entire document does not need to be translated at once.
    • Any translations made will be saved and can be accessed at a later date for completion.
    • The progress of all translations are displayed on the Translation Panel.
    • It is found under Options in the sub-header of the page, while in the Translation Screen.
    • Here in Spanish, Panel de Traduccion.
    • The Spanish translation of the guide shown is 85% complete.
  11. How to Manually Translate Guides, Review!: step 11, image 1 of 2 How to Manually Translate Guides, Review!: step 11, image 2 of 2
    • Once you’ve translated all steps of your guide, you’re ready to see what it looks like in your language! Click on View and quality-check your own translation.
    • Here in Spanish, Ver.
    • If you still need some polishing, don’t worry—everything is fully editable and you can take your time perfecting your work. You can always return to the translate screen by clicking the translate button on the top of the guide. Or you can edit a specific step by hovering over it, and clicking on the translate button on the right of each step.
    • Your translation will be reviewed by another user or an admin before it goes live. More informations on our patrol system can be found here.
iRobot
60 Guides authored
